Problem with Composite structures
Hello,
I am new to ArchiCAD and could use some help. If I have a Composite structure consisting of, let's say 100 mm insulation + 200 mm concrete + 100 mm insulation, is there a way I can create a 3D-view for export that shows only the insulation skins and not the concrete?
I have accomplised the reverse, by setting the insulation skins to "Finish" or "Other", and the concrete to "Core", and then chosen "Without finishes" or "Core only" in the view.
Is there some other way to accomplish this, with say filtering the view by material or something similar?
Thanks in advance!
4 REPLIES 4
Erwin Edel
If it is just for presentation work (not IFC model export, exchanging BIM info), you could make the concrete surface material 100% transparant and it won't show up in renders.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thanks for answering!
Unfortunately it IS for IFC/NWC model export!
I had the same problem. I modeled the construction separate from the finish. This way I could easily export an ifc without the construction. Not the most efficient way, but until there is no other solution within ArchiCAD...
Luckily my project wasn't that complicated.
That seems a bit tedious as this project is roughly 16,000 sqm. Hoping there's some other way.. anyone?
