β2008-12-30
09:42 PM
β2023-05-23
03:06 PM
Rubia Torres
β2009-01-06 03:48 PM
Michele wrote:As you know, this can be set in the Section/Elevation panel of the Grid Element Settings Dialog and can be set individually for each Grid Element element if Suspend Grouping is ON.
Grid bubbles - do they have the ability to be at different heights in different sections and elevations. We want them to be shown in both sections and elevations but the grid bubbles need to be very high to clear the top of the roof and some of our sections are of smaller shorter sections of the building.
β2009-01-06 04:01 PM
Michele wrote:I made the Corner Frame invisible and also set its d variable to zero. Then the horizontal Frames very nicely joined.
Corner windows in the curtain wall - I hopefully included a pic of what I need and want to know how to make the corner "clean up" so that in plan and in elevation it looks correct. There is no frame at the corner condition but when I tried to make a custom frame the width of the glass I got funky things happening (it also asked me for a cap which I did not want but looked like it I had to have one. I tried to turn the frame invisable but then the glass crosses itself in the plan (I wanted all the horizontal frames to continue thru). I tried to make a corner window with the corner window tool but there is no objects that could do what I needed it to do.
β2009-01-06 04:34 PM
Michele wrote:That is probably not the only thing missing from the StairMaker Tool.
Why isn't there a metal pan options in the stair tool? Do they only build those types of stairs here in Wisconsin?!?
β2009-01-06 06:41 PM
β2009-01-07 05:18 PM
β2009-01-07 07:03 PM
β2009-01-07 09:18 PM
β2009-01-07 09:23 PM
β2009-01-07 10:48 PM
