Problems with 8.1 and 9 corner windows
I'm having a couple issues while trying to use the CW Fix 81 corner window. First when stacking two corner windows one above the other the second window created only makes one leg of the window and doesn't create the other leg in the second wall.
Second when working with a single corner window extending one of its legs to the full length of the wall it is in breaks the corner window producing two separate legs. Has anyone run into simular problems and if so how did they go about finding a work around?
Thanks for your help in advance.
0 REPLIES 0
