Learn more
Problems with Closing Wall - Polygonal Method
Hello guys,
my name is Lucas and I study architecture in Brazil. I'm currently working with one reform study of a house in a brazilian slum. The survey was made manually, drawn with Autocad and now I'm trying to model it on AC. I'm struggling with closing irregular wall with the polygonal Method so the Technical Drawing will be correct as well on AC. I tested changing the parameters on the wall's selection definition yet still haven't solved it. Does anyone knows how to solve this?
1 Reply 1
Do you mean that Polygonal Walls do not join correctly to each other and other Walls?
If so, then make sure that the end of their Reference Lines properly join or are consecutive. You can switch the display of Wall Reference Lines ON and OFF with the View\On-Screen View Options\Walls & Beams reference Lines menu command.
