Do you mean that Polygonal Walls do not join correctly to each other and other Walls?
If so, then make sure that the end of their Reference Lines properly join or are consecutive. You can switch the display of Wall Reference Lines ON and OFF with the View\On-Screen View Options\Walls & Beams reference Lines menu command.
