ā2008-02-28
10:38 PM
ā2023-05-23
03:12 PM
Rubia Torres
ā2008-02-29 02:09 AM
ā2008-02-29 03:42 PM
ā2008-02-29 04:47 PM
Link wrote:I have also seen this happen using SEOs (but not the Trim to Roof function). I don't know exactly what caused it, but I knew it was SEO related because the wall was visible in the Story Window, and invisible in all other Viewpoints (and, yes, the windows were there in 3D, floating in space). I canceled the SEOs and the wall reappeared.
I've seen this happen ... Are you using Solid Element Operations to trim your wall?
ā2008-02-29 05:15 PM
ā2008-02-29 05:17 PM
ā2008-02-29 05:30 PM
ā2008-02-29 06:12 PM
ā2008-02-29 06:33 PM
mukster wrote:Click "Browse", select file, and then click the "Add Attachment" button -- only certain file types under a certain size will attach (but you'll be notified if this is the case).
What are the steps to loading a picture? Do I click on the filename, then add attachment button?
ā2008-02-29 06:47 PM
ā2008-02-29 06:51 PM
