Problems with placing roads on mesh...
Hello everybody
I am new with ArchiCAD and am drawing a landscape with roads and buildings, I am trying to add roads on mesh, I did some search about how to do it, but still could not get till the end, my landscape is complicated and to add roads I used fill and then edited it in photoshop and I could not put it back in archiCAD and place on mesh.
pleas help, how can I do it? maybe there is other way to do it...
Thank you for your time
15 Replies 15
vfrontiers
Inspired by this thread, I've done the following upgrade to the processes described below... Check out the jpeg for all the info.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
Along those same lines, you could use a WALL as Property Lines [in place of the Slab as a Road in the previous scenario] and show propertly lines that hug the terrain as well.
Duane
Visual Frontiers
AC3.14 - AC29
Here's a residential site example with yellow lot lines. SEO'd( lot lines 4" wide "walls")( 2' "wall" curbs) (slab road) & Googled mapped material to mesh. Really works well to help clients visualise site issues.
Dave
Thank you all
it's working. but what if i have to place a road with a small heigth towards the mesh level.. how to do this ?
This had to go down as the best thing I've learn form this site - thanks a million guys
