Profile Manager Question
I'm having trouble with the Profile Manager showing the seperation lines or courses in a custom log wall profile. Maybe this is not possible? I have tried to use a different fill in adjacent courses which did not work. the log wall details options are very limited (poor in my opinion) which make for a very unrealistic section view of anything other than a round log.
anybody tried to do this type of thing?
15 REPLIES 15
David Maudlin
Chris:
I was able to get the lines in elevation by adding a small straight segment between the curves. The wall is a single fill. For some reason, two connecting curves do not yield a line, even when using alternating fills with different material assignments to their curved faces.
HTH
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Eduardo Rolon
assign a different side materials to each fill, that should give the result. Only 2 materials needed.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
cremsberg
I was just now working on an eave detail, using different fills where the pieces abut. Maybe this has improved in version 12, but separation lines seem to happen in section as you would expect if the fills are different. Does anyone know how to control fills of 3D elements in section so that some elements have opaque backgrounds and others have transparent? Is this controlled in profile manager? section settings? preferences? I cannot find.
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
guys iv created a simple polyline prfile on floor plan.
Now im looking for profile editor.
I just cant find it... looking for about 20 minutes now... girrr.
any help would be great.
thanks.
Ian
cremsberg
Hi Ian - I do not know which version you are in, but as I am still in version 12, I find the Profile Editor here: Options / Element Attributes / Profile Manager. In AC14, it is in the same place. Good Luck
Claire Remsberg
after asking and search and searching, found it.
here is the location ( see pic)
