Profiled Rail in my ArchiCAD file disappeared!
moreha-1
Dear friends and colleages,
I would like to know how I can bring back (Profiled Rail 26) feature to my ArchiCAD file!
I don't know why this feature of Railing Tool has been disappeared from Railing Dialog Box of my file!
Your kind help and guidance is highly appreciated
All the Best
Guru
That should be part of the AC26 Library lcf? Is it loaded?
Hello @moreha-1,
You have to change your Archicad Work Environment Profiles into the Option menu.
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
Guru
