Bruce
Profiled railing display bug
I have encountered what I believe to be a bug in the plan display of the railing tool.
If you use the option for a profiled railing, and the profile you use is not centred around the origin, the railing will 'split' in plan at the ends / change in vertical plane. The 3D will still be ok though.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
10 Replies 10
Bruce
I should point out that the complex profile only creates the crank in plan: the normal profile (i.e. Rail 21) will still have issues with plan not aligning with 3D on raking ends; and curved corner junctions disappearing when joining a raking portion within a certain distance.
(This should all be under case #239955.)
Cheers
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
