‎2008-08-01 11:17 PM
‎2016-12-27 12:22 PM
‎2016-12-29 02:50 PM
‎2019-02-11 10:24 AM
ispyridis wrote:I don't get this. I have already transformed GGRS87 points to WGS84, aren't those already La/Long? As far as Iknow Google Earth uses WGS84
3rd translate the WGS84 values of the chosen project zero to Lat/Lon and use these values to define project location
ispyridis wrote:When I import the mesh based on WGS84 the resulting mesh is placed on project origin BUT: 1) It is extremely small, 2) The conversion isn't done properly. Even when I scale it properly the distances between points are progressively losing accuracy. Notice that I checked the converted dimensions with Google Earth and they are correct.
4rth import relative coordinates you prepared in excel with import mesh from surveyors data. Now your site will be imorted on project origin.
‎2019-02-22 10:19 AM
