Project Origin Question...
I know how to move the user origin as I please....
How about moving the Project Origin? Any ways of achieving this?
Thanks in advanced.
13 Replies 13
I also want to make a wish for Graphisoft. When saving a project as module, to keep the project location. And when imported to another project to be able to be placed using project location data. This will give the opportunity to teamwork on cities. It will give GIS functionality to archicad. Imagine a teamwork project located on a bim cloud or server in the city planning department and every architect can place his project correctly in that large file.
Thanks
Here is a short video that shows how I do it for GGRS87. I'm sure it works for other countries too.
https://www.youtube.com/watch?v=8mYRKs9oOec
Achille Pavlidis
Hi ispyridis, I'm trying to follow your instructions, but cannot obtain the desired outcome...
ispyridis wrote:
3rd translate the WGS84 values of the chosen project zero to Lat/Lon and use these values to define project location
I don't get this. I have already transformed GGRS87 points to WGS84, aren't those already La/Long? As far as Iknow Google Earth uses WGS84
ispyridis wrote:
4rth import relative coordinates you prepared in excel with import mesh from surveyors data. Now your site will be imorted on project origin.
When I import the mesh based on WGS84 the resulting mesh is placed on project origin BUT: 1) It is extremely small, 2) The conversion isn't done properly. Even when I scale it properly the distances between points are progressively losing accuracy. Notice that I checked the converted dimensions with Google Earth and they are correct.
Mac OS 26.1 | AC 29.0.2 INT 3200 FULL
Hi Achille,
3rd WGS84 coordinates are in metres the project location dialog accepts decimal degrees or degrees minutes seconds you need to transform meters to decimal degrees. Only one point the one that corresponds to project zero.
4th it seems you need to multiply your values by 1000. If you had metres but you were working in millimetres your values were recognised as millimetres and the mesh got scaled down.
Hope this helps.
