Project index schemes
KeesW
i cannot find this command. Is it yet another item that needs to be loaded before it can be used? If so, how and where.
Cornelis (Kees) Wegman
cornelis wegman architects
2 REPLIES 2
Eduardo Rolon
If you don't see it under Document-> Project Index then check that you have a standard or default Work Environment loaded, specially Command Layouts.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Or just go to it in the Project Map list.
Just like Interactive Schedules you can Import an Index so if you have one in another job (or the default Archicad template) you can Export them from there and Import them into your current job.
Or set them up yourself from scratch.
