2020-04-2211:38 AM - last edited on 2023-05-0903:53 PM by Rubia Torres
2020-04-2211:38 AM
I need to intersect the selected wall with the thicker wall (which is not orthogonal) and I cannot intersect them seamlessly. Sometimes it works but when the wall is not orthogonal, no matter how I rotate the thinner wall it doesn't let me intersect them. Is there a solution?
In addition to my first question - what I want to do is - to seamlessly merge the thinner corner walls (it's a pilaster) with the thicker walls. The problem is that if it works on the one side, on the other side they don't get properly merged/intersected. It's an old building with crooked walls and the intersection method does not always solve the problem.
Thank you! I used the poly wall. It partially worked. The only issue that remained unsolved - I need to either split it or somehow connected it to the other wall seamlessly. But if I split it - a line appears, if I try to intersect two poly walls - it doesn't let me do it.
Thank you! The issue got magically solved. After the fifth try, it worked. I don't know about the reference lines. I'll have them in mind for the next time. I just needed it seamlessly connected.
You can use the "View > On-Screen- View Options > Wall and Beam Reference Lines" menu command to display or hide those Reference Lines. They probably join now. When you are editing a polygonal Wall geometry, the Reference Line location of the Polygonal Wall can also change, it can get shorter or longer.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac28
