Question about wall intersection
I need to intersect the selected wall with the thicker wall (which is not orthogonal) and I cannot intersect them seamlessly. Sometimes it works but when the wall is not orthogonal, no matter how I rotate the thinner wall it doesn't let me intersect them. Is there a solution?
7 Replies 7
In addition to my first question - what I want to do is - to seamlessly merge the thinner corner walls (it's a pilaster) with the thicker walls. The problem is that if it works on the one side, on the other side they don't get properly merged/intersected. It's an old building with crooked walls and the intersection method does not always solve the problem.
runxel
Use a Polywall instead. (Not the Polyline method, but the real poly)
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Thank you! I used the poly wall. It partially worked. The only issue that remained unsolved - I need to either split it or somehow connected it to the other wall seamlessly. But if I split it - a line appears, if I try to intersect two poly walls - it doesn't let me do it.
Make sure that you extend the Reference Line of the Polygonal Wall so it connects to the Reference Line of connecting Walls.
runxel
As Laslo says: Take care of your reference lines 🙂
Thank you! The issue got magically solved. After the fifth try, it worked. I don't know about the reference lines. I'll have them in mind for the next time. I just needed it seamlessly connected.
You can use the "View > On-Screen- View Options > Wall and Beam Reference Lines" menu command to display or hide those Reference Lines. They probably join now. When you are editing a polygonal Wall geometry, the Reference Line location of the Polygonal Wall can also change, it can get shorter or longer.
