Questions around the "Building Materials" window
hi all,
I have some questions about topics emerging around the "Building Materials" window:
- Where does the data for the Physical Properties came/come from?
- Is there a way to disable automatic intersection/merge behavior between walls/slabs with the same material? (see screenshot below)
- What are known use cases where one needs the material classification (IFCMaterial)?
Thanks for any comment or hint!
Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
1 Reply 1
Carstenem
Hi Florian good questions but
The first and last question is quite a bit to answer and there is enough information out there. I recommend next time to do a google search first before asking this type of questions here.
1. Answer: https://helpcenter.graphisoft.com/user-guide/65686/
2. Answer: just duplicate the material of the bench and apply to the bench top, then AC will not "delete/merge" the lines. Like bench material name - dark wood 1 and bench top - dark wood 2
3. https://helpcenter.graphisoft.com/user-guide/65294/
Hope this helps.
Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
