2005-05-04
10:38 PM
2023-05-26
03:15 PM
Rubia Torres
2005-05-04 10:49 PM
2005-05-05 01:06 AM
TomWaltz wrote:Tom,
Did you try a "New and Reset All" to see if it comes back? It could be some glitch within the Work Environment. (not accessible via the interface)
2005-05-05 02:08 AM
2005-05-06 06:19 AM
2005-05-06 08:48 AM
johncassel wrote:i often get this with the Library Loading Report window. it's 'remembered' state is different to that displayed in the Window menu.
... it is not shown on the Restarting ArchiCAd Window/Palette Display menu.
2005-05-06 12:23 PM
johncassel wrote:John,
The restart ArchiCAD seems to work to get the Quick Layer Palette back in the game. We generally look at New and Reset as a last resort solution as we then need to reset our Work Environment, etc. We used to use the New and Reset when the v8 toolbar would just disapear and not be found.
2005-05-06 08:28 PM
~/archiben wrote:Ben,johncassel wrote:i've actually made the quicklayers a part of toolbar. i see no reason why you couldn't define a specific toolbar for this purpose (if there isn't already) and save that as a part of the WE profile? it's a workaround, but one which may suit you until a fix?
~/archiben
2005-05-06 08:41 PM
Ben wrote:Ben,
John,
This simply should not be happening. If you have to redo your WE after a New & Reset, some thing else is wrong. Have you stored your profile? If you have your profile set as the default profile, after a New & Reset, it will be the WE that shows up after the New & Reset.
Cheers.
Ben
2005-07-24 04:54 AM
