Quick Layers Palette disappears
We have two computers in our office running ArchiCAD 9 (2018 USA FULL). From time to time the Quick Layers Palette disappears. The Quicklayers Palette cannot be invoked with our Keyboard Shortcut and it is not shown on the Restarting ArchiCAd Window/Palette Display menu. It is also not available under Options/Work Environment/Palette Schemes or anywhere else that it might normally show up in the Work Environment menus.
Because this is happening on two machines that are independent of each other we think it is a bug in this version of the software.
Please let us know if there is a solution or fix to the problem.
Thank you,
John
21 REPLIES 21
kevin b
And that would work in 10 as well because when I do turn it on via the menu it shows up in the right spot where I left it so I'm sure assigning a shortcut to it would turn it on in the right place. But its just odd that this seems to be the only palette this happens to. Admittedly I have not tried them all but most.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Thomas Holm
Odd, yes. Still a bug. Never turns up where I left it. Although it seems to dock just like toolbars. What's the REAL difference? Different programmers, I guess.
