‎2006-12-26
06:46 AM
‎2023-05-25
05:57 PM
Rubia Torres
‎2007-01-01 11:04 PM
Geoff wrote:Aha, so that's how to get rid of the annoying floor slab lines that show up in my elevations!
I would extend this to finished flooring as well. Then the structural floor system can be easily subtracted from the exterior walls (w/ SEO) to get a proper junction
while the interior walls can be set on the subfloor without the need for SEOs. It requires more steps and demands more maintenance but yields superior results.Yeah, it sure does require more maintenance! I find just keeping track of what I've done and what I haven't is a challenge, owing to how thin these finish slabs and walls are. They just aren't readily visible without zooming in really closely.
Here's an instance where I would like some of Revit's lock features so I could connect the finished slabs to the bounding walls.You mean other than just locking the slabs as we already can do in AC?
In this example the finish floor and ceiling slabs would be fastened to the structural slab such that the whole assembly could be moved up or down (z axis) as a single unit while their edges could be linked to individual wallsThat really would be terrific!
‎2007-01-01 11:18 PM
Archi wrote:Why dangerous?
To make RCP completly in 3D is very very dangerous and many work (enough nonsense).
Without lighting fixtures and air ducts and so on....
‎2007-01-02 09:19 AM
Geoff wrote:Perhaps this is a job for your
‎2007-01-02 10:08 PM
‎2007-01-02 10:15 PM
‎2007-01-03 02:15 AM
‎2007-01-03 04:36 AM
‎2007-01-04 01:11 AM
Wendy wrote:Yes.
So you do use separate slabs for each ceiling from the floor slab above, if I'm understanding you correctly?
Yes
Erika wrote:That's a great idea!
I find this works well. For fixtures you use often you could also develop a set of 3D lights whose 2D symbol is the graphic symbol you want.
I'd have to do this in the GDL script, wouldn't I?
Wendy
‎2007-01-04 06:48 PM
Wendy wrote:
What I find to be a pain is not having these 3D parts automatically show up as proper, standardized 2D symbols in plan for CD purposes. No one understands those miniscule little circles and other weird elements that show up otherwise, and it's double work to go back through and manually place the 2D symbols on a whole separate layer.
Or maybe there could be a checkbox in the item's info box where you can turn the standard 2D symbol on and off, so you can still verify sizes and dimensions of the actual objects in plan.
Wendy
‎2007-01-04 08:00 PM
Laura wrote:Thanks for the reminder, Laura; I'd forgotten about this.
Wendy -- Some of the standard library parts already have this option
