2022-07-11 11:10 PM
HI,
I'm looking for where in Graphic Override Rules how to control "Solid Cut Fill", tick box.
There appears to be 3x rules called Solid Cut Fill, one Black, one Grey & the other white?
Please see attached.
Solved! Go to Solution.
2022-07-12 03:32 AM
Renovation Filters do not use the rules that you can customise or create - the Graphic Overrides use these.
They only use the 3 renovation rules.
The 'Additional filter options' are just options you can turn on/off.
In your case for '03 Planned Development' you have told the 'Existing Element' to use 'Solid Cut Fill'.
So it will use the cut fill set in the 'Existing Elements' rules - and not any of the other rules that are only for Graphic Overrides (crossed out in purple in my image).
At least that is my understanding of how it works.
2022-07-12 03:32 AM
2022-07-12 02:40 PM
I see. Thanks Barry.
