‎2006-04-28
02:20 AM
‎2023-05-23
03:30 PM
Rubia Torres
‎2006-04-28 03:09 AM
Tom wrote:They can be copied within the same roof, but not into others.
Can roof holes be copied and placed in a different location in the same roof, or other roofs.
Also, what is the easiest way to erase (fill in) a roof hole. Do I have to put all the hole nodes on top of each other until they are all gone? Pretty tedious for a lot of nodes.
‎2006-04-28 06:06 AM
‎2006-04-28 06:16 AM
‎2006-04-28 07:16 AM
‎2006-04-28 09:23 PM
Miki wrote:Well, I could have told him to click "Edit > Clear" but it seemed faster to use the Delete key instead.
Tom, what you are talking about ? Selection part was OK, but why hit Delete ? Once you have your hole selected (works on roofs, slabs, hatches) use move, rotate, copy, multipy etc...
‎2006-04-28 10:36 PM
‎2006-04-29 03:22 AM
‎2006-04-29 05:34 AM
Tom wrote:Right click on the hole edge, choose Clear - or whatever else - from the context menu
I already know how to delete, but thanks anyway. The real question is how to select it.
‎2006-04-29 06:35 AM
You dont even need to shift click to select the hole - just click on it and only the whole will highlightOnly the
