Rafter and Ceiling Intersection..
I spend quite a bit of time going back and forth from section to plan to properly locate and draw these dashed lines... There must be a quicker way to make rafter and celing joist intersections visible? Also, the 7' wall is an SEO'd 10' wall but I have to measure/calculate to get this since wall info is the same even after SEO...
gpowless
Yes there is.....
Select the roof and then Tools:Create Roof Level Lines. Input the ceiling height (or the clip height that you want). The lines will appear.
Intel i7-6700@3.4GHz 16g
Thanks.. Though they have to be regenerated whenever the roof is changed that helps.
