‎2018-10-22
03:27 AM
‎2023-05-23
06:02 PM
Rubia Torres
‎2018-10-22 05:23 AM
‎2018-10-24 05:15 PM
Lingwisyer wrote:
2. After creating the railing with the outer posts, if you select it, you should get an "Edit" prompt appearing. In edit mode, you can select one of the outer posts and delete it.
Ling.
‎2019-02-14 02:17 AM
‎2019-02-14 02:46 AM
dcerezo wrote:Yes that is correct.
I'm having an issue with the materials as well. It seems you have to change each component individually. Is there no way to change the entire rail's materials all at once?
‎2019-02-14 04:10 AM
‎2019-02-14 04:15 AM
‎2019-02-14 05:00 PM
Marina wrote:Not sure if this is what you're running into, but for me, in the default AC22 template, for some reason Override ______ Surface under 3D Representation is turned on by default for a bunch of the railing components, so changing the Building Material under the Style and Dimensions section of the component's Component Settings doesn't appear to do anything. You can turn off Override ______ Surface for that component and the Building Material settings will take effect.
3- I cant change the rail material. I change the material for all the components but it keeps the default aluminum material. Ive tried a lot of different materials, just doesnt work. Other objects change material normally.
‎2019-02-16 01:08 AM
