2023-03-28
10:39 PM
2023-05-09
03:11 PM
Rubia Torres
I have developed a custom inner post that has a 2" void in the center. The intermediate and bottom rails continue through the custom inner post. Does anyone know of a way to interrupt the rails? I looked at making a custom panel, but that is not available.
Solved! Go to Solution.
2023-03-28 11:11 PM - edited 2023-03-28 11:13 PM
Hello @rgarand,
Did you try to use SEO ?
I use to ajust my railing modelisations by this way.
2023-03-29 03:23 AM
Yes.
Just go into edit mode for the railing and SEO the elements you want.
You may need to use subtract upwards/downwards seeing as your post has a void in the middle.
Hello @rgarand,
2023-03-28 11:22 PM
An SEO within the Custom Post Object?
2023-03-29 03:23 AM
Yes.
2023-03-29 06:05 PM
Ahhh excellent...and when you pick one Inner Post they are all selected. This worked great, thank you.
