Railing Tool - Custom Railing Post not showing on Floor Plan
Hello! Happy Holidays,
I am having trouble modeling with a custom post and the railing tool. I created a post and used the 'Save selection as Railing Post', but it deleted all the 2D representation. I have tried to edit MVO, as well as 2D symbol options within the railing, but I cannot get the post to display correctly. Any help would be appreciated.
Operating system used: Windows 11 24H2
Screenshot 2025-12-22 083331.pngScreenshot 2025-12-22 082853.pngScreenshot 2025-12-22 084154.png
Archicad 27-28, Windows 11 Pro, NVIDIA RTX 5090, AMD Ryzen 9 9950X3D 16-Core Processor - 4.30 GHz, 96.0 GB
1 Solution
cuba
A custom post has no 2D projection.
Save the column you made as a custom object (not as post).
Open the library-object (select + ctrl-shift-o/command-shift-o) and change the subtype into railing post component.
This post will now be available in the post-settings
Apple M1 Max 32 GB
Latest AC
Go to post
2 Replies 2
cuba
Apple M1 Max 32 GB
Latest AC
Thank you Cuba,
I also found this suggestion as a workaround: https://community.graphisoft.com/t5/Modeling/Railing-Tool-Basics-How-to-create-a-2D-symbol-for-a-cus...
But I am glad to see that there was another way. Thank you so much for your help.
