Railing Tool and Slab Openings
cmartonffy
Hello ARCHICAD Community,
Are there any good techniques for "closing" rails that are only associated with a slab opening only (i.e. not stairs) so that:
  • corner mullion
  • top rail
  • adjacent panels
appear closed?
See image attached.
Thanks,
Claudio
AC 23 | INTEL i9-9900 64GB RAM| NVIDIA QUADRO P1000 4 GB GDDR5 |WIN 10
USER SINCE AC 19
runxel
Hero
I forgot to mention:
You'll have to start your railing not at the corners, but at the node you added on one of the edges.
5 REPLIES 5
runxel
Hero
Until GS fixes this hot mess:
You can overcome this if you make an additional point on one of the sides. It will now close properly, BUT: at the cost of an additional post at this node. (you might be able to delete it in edit mode, but that depends on your design of course)
Also you can't use the magic wand. You have to do the railing by hand (it's still associated tho).
cmartonffy
Thanks runxel,
I am really trying to get a profile (see image) to turn corners of a closed polygon ... was having issues with the curtail wall tool so I tried with the rail tool.
I will try to use the curved glass profile as a mullion instead of a panel in the CW tool, but I am having trouble understanding the cutting planes.
This could be a job foe the grasshopper connection, but I was trying to keep the workflow easy for the concept phase;)
Claudio
USER SINCE AC 19
runxel
Hero
Lingwisyer
Guru
You set your rail endings to ZERO, so that they basically butt into each other.
cmartonffy
Thanks all for your responses.
Claudio
USER SINCE AC 19
