Sefa Yakut
Railing and Stair Connection Problem
Hello everyone
When I hold down the spacebar in Archicad and draw the railing, I see that there are problems in the details of the junction with the staircase. How can I fix this? Is there any way to fix these struts other than converting the railing to static and fixing it one by one in 3D?
SefaYakut_0-1703506957421.pngSefaYakut_1-1703506975907.pngSefaYakut_2-1703506997566.png
2 Replies 2
Marc H
Others may have better luck with the wand, but I've had unexpected results with 'wizards' ever since they were created in software.  I take it a bit slower by implementing the railing tool and snapping to the points I want.  Takes time, but once I have a stair and rail I like, I'll save to Favorites.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
cuba
You can try the following:
In the segment settings:
1/ Set pattern length to number of steps
2/ Set start from center to get post in the middle of step
Apple M1 Max 32 GB
Latest AC
