Railing design with Railing Tool
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-02-11
11:55 AM
2023-05-23
05:59 PM
Rubia Torres
So, am I missing something that will make those inner set in place?
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-12 02:54 AM
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-12 04:19 AM
The long post is an inner post.
Unless you are going to add a node along the length of your railing at the point of each of those long posts.
Normally you would only have nodes at the ends/corners of the railing.
You could create a custom inner post consisting of the long post with a shorter infill post on each side.
So effectively the 3 posts become one.
Create I custom corner post as well but with only one short infill post (I didn't do that.
Then add an infill panel and use a material for the wire with an alpha channel image to save trying to create a custom wire panel that probably wont stretch all that well (I didn't do that either - just used plain glass).
A bit like this ( I haven't set the horizontal rails properly either - just a quick 2 minute proof of concept) ...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-15 09:46 PM
There are a few points that are worth making about how this can be done:
1. The most important one is that it is possible to have more than one Inner Post within a single Railing Segment as you can see on the above screenshot. You switch to the "Inner Post" page of the Dialog, and with the use of the "+" button in the top right corner of the preview area, you can add multiple Inner Posts. Archicad will always take the rightmost of the placed Inner Posts and consider that to be the right edge of the Segment.
2. When specifying the position of the individual Inner Posts, it is possible to lock their distance to a specified value from the left edge of the Segment/Inner Post to their left by clicking on the LOCK icon to the right of the "Distance to Previous" field. In this example, we have 3 Inner Posts. If you lock the "Distance to previous" value for the first and third and set them to the same value, you can achieve the symmetrical look shown on Red's image.
3. You can also define the top and bottom of Inner Posts relative to Rail 1 and Rail 2, which are the upper and lower boundaries of the first and second Inner Posts on Red's image.
4. Regarding the Panel, I, too, would probably create a custom GDL panel, that consists of that grid or net, with its thickness, width and height, plus X and Y offsets for starting position of the grid as parameters. Or, Barry's image panel suggestion would also work.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-16 02:28 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-16 03:13 AM
Lingwisyer wrote:
Multiple inner post types, completely overlooked that...
Yes.
I knew we can have multiple rail, handrails and balusters.
I didn't even think of multiple inner posts.
There is that consistency we are always asking for.
That suggestion of Laszlo's is better than a custom post as the individual post heights can be controlled by the rail heights rather than as one custom post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-21 12:50 AM
Red
i7 8700k
64gb RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-21 12:56 AM
Red
i7 8700k
64gb RAM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2021-02-22 03:16 AM
Adding extra nodes just gives you more (different) control.
So each post becomes a 'node' post rather than an 'inner' post.
Same but different.
