2022-11-28
04:59 AM
2023-05-09
03:11 PM
Rubia Torres
Does anyone know how I can connect this railings termination?
Solved! Go to Solution.
2022-11-28 05:29 AM - edited 2022-11-28 05:37 AM
Has been an issue since the Railing tool was introduced. You cannot do a closed path. The closest you can get it to terminate on an edge, removed the unneeded post, and set the rails and toprail to have zero end offset.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2022-11-29 04:07 AM
Base railing;
Zero ALL of the end offsets;
Zeroed offsets;
Given posts and balusters, in EDIT MODE I have deleted one END POST and changed the size of the other to match the balusters;
Result;
Ling.
2022-11-28 07:25 AM - edited 2022-11-28 07:26 AM
terminate at the middle of the side, not at the corner, as described above. that is the solution to the bug.
2022-11-29 01:27 AM
I'm not sure I understood the process exactly. I tried to do it but it was looking like a big kludge. Changing the offset value to zero didn't seem to have any effect. I got something close just by dragging elements in the edit window.
Perhaps a video will make this process clearer. If it's not asking too much. Thanks in advance
2022-11-29 01:58 AM
The continuing corners will trim as you expect.
The start and ends will not trim when forming a corner and there is no way to mitre the ends unless you perform you own Solid Element Operation.
By starting in the middle of a straight edge, the ends will abut each other perfectly, but you may end up with a joining line.
2022-11-29 04:07 AM
Base railing;
Zeroed offsets;
Result;
