Not sure why it is like this - all the openings seem to have different minimum values.
You can press the 'Empty Opening' button at the bottom left of the settings dialogue.
You will lose some of the parameter options but that probably doesn't matter if it is just a plain opening.
At least there will be no minimum size.
