Your storeys are your reference planes.
Your slab should have the reference plane location of the slab (the blue line when selected in 3D) set at the top of the slab so the thickness then goes below the storey.
Walls are placed with their base height at zero so they will start at the storey (floor) level and sit on the slab.
Doors and windows can have their base or head heights set relative to the storey or the wall - it all depends on how you want to work.
Objects are place relative to the storey as well so for a chair on the floor the base height of the object would also be zero.
For something higher like a wall mounted cabinet you would just set the base height appropriately in relation to the storey (floor).
A simple rule is to create a storey for each floor level - all elements are placed relative to the storey you want them on.
i.e. the base height will be zero, whether you are placing the element on the ground floor, first floor or second floor - but the base height will be relative to each particular storey.
