Reflected Ceiling plan
I am having a problem when it comes to putting recessed lighting in my ceiling plan. As you can see from the grid, and the 3d they don't match up. Can anyone help me to fix this?
Justin
6 REPLIES 6
TomWaltz
I'm guessing that's a bit map on your ceiling, representing the tiles?
I've had a lot of long days fighting to make the plan match the 3D bitmap textures....
Tom Waltz
Yes, I am using the bump tile I found on the forum long ago.
Justin
You should be able to move the Fill origin on your plan, which is not related to 3D texture alignment.
Or is it???
They are somewhat weird when it comes to the texture orientation.
Justin
TomWaltz
Or is it???
I don't think they are related, but that's a pretty tricky order to make sure two things line up that you cannot see at the same time
Tom Waltz
Here is how the ceiling turned out.
Justin
