Reinforced Precast Concrete Slabs
Is there a way to model precast reinforced concrete slabs suitable for engineering testing or are these models available
Peter,
Do yu want to build the precast from the drawing OR do you want the software to perform a synthetic analysis of the performance characteristic in software?
If the first answer, then model your slab with Composite profiles, if the second, then you need simulation software. I don't know if there are add on for Archicad, but you should contact your vendor.
Snap
