Reload library command?
JohnJay
Is there a command to refresh all libraries (same as 'Reload and Apply') without needing to open the Library Manager, clicking or reload and then closing the window?
AC27 | i7990x | RTX4070 | W10
I believe this command is what you're looking for...  You can add it to a menu... or add a shortcut key combination for it.  Note that there are quite a few commands available in the Work Environment that don't exist in the standard menu structure.  You might find something else useful in the list of all commands...
ā€ƒ
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
ā€ƒ
Thank you Karl
Yes that was it.  I did do a search for 'reload' but nothing came up
I was missing the "All commands in alphabetical order" in the drop down below the search bar
