Remove +/- sign in reference levels
Hi All,
Does any one know if you can remove the +/- sign on reference levels? (Sections, elevations and plan levels).
Please see image attached.
Cheers
1 REPLY 1
Eduardo Rolon
You can remove the +/- 0'=0" which drives me nuts but then you will only get indication for the "-" levels.
Look under the Text Settings for the Story Levels that are within the Section/Elev Settings.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
