Removing the spider junctions at curtain wall?
I added junctions to my Curtain wall, by using the "At all Grid points" option from "Curtain Wall Selection settings".
Now I want to remove all these junctions.
How can I do that?
Edit->Undo would not work, as I already saved the file, and quit Archicad.
I am working with Archicad 14.
Thank you.
1 Reply 1
I got it:
Select the curtain wall, "Edit" turn off all other options except "Junctions", select all junctions, "Delete" button on keyboard, turn on all the other options again, Ok.
