qwsoftdraw,
The palette is possibly the easiest way to set your defaults. You may also open the Default settings of your tools and set the Renovation Status under the Tags and Categories panel.
Under normal cisrumstances you can make the Renovation palette visible by going
Window > Palettes > Renovation. But since you do not see it:
A. In the Work Environment dialog:
- Click
Menus on the left
- Choose to
List: All command in alphabetical order
- Scroll to
Show/Hide Renovation Palette
- Drag it to the Menu you wish to have it in on the right.
OR, if that is not working for you:
B. I suggest that you
and then apply the Standard Profile 19. From there you may edit the Profile to use your custom Shortcut scheme and Workspace scheme. But if you go so far as to edit your Menus you should re-add the items you prefer manually.
I hope this helps.
Best regards,
