Daniel Lindahl
Renovation / house raising
This is a typically Australian scenario: I am doing a renovation that involves lifting the existing house and building in underneath. I think I have to use 2 files because of the changed floor levels.
Has anyone worked out a good way of documenting such a renovation within a single file, using the renovation toolset?
cheers
Daniel
Daniel Lindahl Architecture
AC24 | Dell Inspiron 16+ | Windows 11
Erwin Edel
I would probably try publishing a multistory module file from the existing building and linking that to your new building file.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
I would probably model the building so the existing floor is the upper floor level, and just lie (i.e. 2D) about levels and ground lines on any existing elevations and sections. Use renovation filters to distinguish between existing and proposed.
