Renovation tool and archicad defaults
KeesW
I've discovered an annoying feature in the renovation tool. The CTR-Alt used to copy lines and properties does not apply to the Renovation tool. For example, I've got some lines selected as 'New' and I want others to match. CTR-Alt won't convert lines inadvertantly entered as 'Existing' into 'New'.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
7 REPLIES 7
Correct. The syringe does not pick up the Renovation status. It would be good if it did.
Aaron Bourgoin
My syringe picks up reno status. Better drugs in mine, I guess. :- )
What's cumbersome is having to use the reno palette to establish defaults.
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
That is interesting Aaron, your version must be special.
My ArchiCAD does not pick up Reno Status either when using Parameter Transfer with the syringe cursor shape.
So you say that you have an Existing Wall and a To be Demoed Wall, both are visible, Demo Wall shown with override, you ALT-click (or its Mac equivalent) the Demo Wall, CTRL-ALT-click the Existing Wall and that Wall switched to Demo Status, Floor PLan color overridden and all?
Aaron Bourgoin
Not so special today. Laz! :- (
Tried again to confirm as per your question. FAIL!
Rhino 8 Mac
MacOS 15.2
OK, thanks for reporting back on it.
To my knowledge, Parameter Transfer not picking up Reno Filter status is the expected behavior.
What is a different question and what would be interesting to find out is whether this is good this way or not.
I can see value in Parameter Transfer being able to transfer Reno Filter Satus as well.
KeesW
Laz
I see no reason why the syringe should NOT work in the Renovation Tools. Can you give me any?
I don't see any reason either but that is currently the case.
I think it would be a good addition to Favorites settings to be able to define whether Reno Filter status goes through or not.
The reason I wrote my previous answer this way is because I did not want to influence others with my personal opinion, but since now you asked, I am stating that in my opinion it would indeed be a useful option.
