2006-06-22
03:40 AM
2023-05-23
05:15 PM
Rubia Torres
2006-06-22 04:02 AM
2006-06-22 04:58 PM
I have downloaded the INT edu version and have been busy updating our templates.John, I don't think you will be able to use what you have developed on the EDU version on your Pro version of Archicad. While the file format is the same .PLN, once a file is opened in the EDU .PLN it will always think it is an EDU file and will print the WaterMark. I think it is OK to get started learning 10 on the EDU, be carefull don't expect to use that file on the Pro version.
