Aussie John
Reproducable V10 crash?
Open the default template file and add object. View an elevation showing the object. Choose the object and select "label elements" and choose a non text label such as object label. View in layout and Archicad will crash when the view updates.
Can anyone else verify this or is it something here?
To get a headstart on the rest of the staff I have downloaded the INT edu version and have been busy updating our templates. Maybe the shipped version will be OK- i'll know next week.
UPDATE: not all labels cause a crash but the default object label definitely as does a custom one I had in v9
Cheers John
[/size]
Link
No problem here with the INT817 FULL version.
Link.
David Pacifico
John, I don't think you will be able to use what you have developed on the EDU version on your Pro version of Archicad. While the file format is the same .PLN, once a file is opened in the EDU .PLN it will always think it is an EDU file and will print the WaterMark. I think it is OK to get started learning 10 on the EDU, be carefull don't expect to use that file on the Pro version.
This is my understanding, I maybe wrong, but I don't think so.
I was able to reproduce your crash on my Pro USA 817 build. Got the bug reporter and sent it in.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
