!Restored: ArchiCAD 12+?
As the debate on the relative merits of ArchiCAD 11 rolls on, and we all digest what still remains to be addressed, there are obviously numerous issues that remain unresolved.
Some we have learned to live with, and find workarounds for. There are others that I believe are much more fundamental.
One of those is how ArchiCAD deals with curved surfaces.
Many people fail to understand that in ArchiCAD, curved surfaces become facetted in Views AND 2D section and elevation windows. It is like turning a vectorial line drawing into a bitmap - it might look OK but try doing anything that requires accuracy (like, for instance, working drawings!) and you are in trouble....
I have prepared a PDF (refer attached file) complete with an example explaining the problem.
Please consider lobbying GS as I reckon this will become more & more of a problem...
10 REPLIES 10
Rafal SLEK
Are You sure that Wishlist isn't better place for Your thread?
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD 28/Twinmotion 2024
Wokka
Hey Robert,
I feel your pain!
I've actually added this to the wish list for the last 5 releases, ever since R5 had real curved walls!
We use a lot of colorbond in our designs, often with curved roof elements and just the annoying facets on 1:100 elevations is bad enough, let alone construction documentation.
I'm resorting to using special profiles just to get the 3D looking right.
Warwick Lloyd-Martin
3 D E N V I R O N M E N T
http://www.3de.com.au
Windows 11 Pro 64bit
ArchiCad 4.55>27 AUS
Lumion 12.5/2023
D5 Render
Rob
Administrator guys, could you please move this topic into the wishes section just keep it more and logically accessible to the wider audience I suppose...
Anyway Rob, I fully agree with your comments as the current curved roof tool is a dinosaur in terms of actual usability. it's almost ridiculous...
::rk
stefan
While I don't often use curved surfaces, I do agree with a commitment to a more robust geometrical core in ArchiCAD. Real curved (or planar) roofs, walls and floors, which correctly intersect and produce reliable sections are very important for the Virtual Building.
Now AC11 is released I hope the programmers have a short (well-deserved) break and the project management team focuses on improving the Virtual Building before all else. I still have major complaints about intersections between multilayered floors with multilayered walls, which is also fundamental, IMHO.
Archicad-user since 1998
my Archicad Book
Djordje
No need to move the topic to Wishlist. This is the place for all general discussions about Archicad.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
From your document, you note that Revit may better represent curved surfaces. I should note that even if Revit does, it doesn't necessarily make the situation more usable. Snapping to these objects in many cases (when the cut plane is not parallel to the object's curvature) is impossible. Dimension references will not pick up the object at all. A short 2D line has to be drawn for the dimension to snap to.
stefan
Having real curved surfaces is one thing, making them act as real building elements (e.g. placing windows, deriving schedules, properly dimensioning them) is a whole other problem.
The visualization is almost there (with issues), but the other aspects, essential for BIM, are far from being realized. But I don't think that there is any software for BIM, at the moment, that does this correctly. You might try CATIA/Digital Project, but I assume that what you gain in surface capabilities will be lost on other aspects: drafting and correct construction documentation? I don't know...
my Archicad Book
Clean 2d is a major need . Sometime is difficult to have both 3d and 2d clean in the same project. For example the shaded + shadow elevation for circular columns in AC11 is better than older versions but can be better maby using a fill like Linear gradient fill for cilinders or Circular gradient fill for spheres optimized for 2d representation .
The real source of the problem is translation from mathematical curve to something that your graphic card can understand. Even Revit is faceting. Create a curved object and zoom very close and you will observe it. In Autocad it is even worse, because you have to use regen after zooming. Even in Rhino that is nurbs modeling software you have parameters that define how the objects will be faceted in 3D window. We probably should complain more to the graphic card producers to incorporate accelerated display of mathematical curves and surfaces.
Going back to the problem you can typically resolve it by splitting object to the smaller pieces. And as I remember even if your display shows faceted wall that differs from the real curve, the snapping will lead to there actual curve, so there should be no problem with accuracy.
