2008-05-09 09:47 AM
2008-06-12 06:19 AM
Miki wrote:Perhaps you just need more ram.
we have a special 64 bit 8 core 167GB RAM machines for this project, .
2008-06-12 06:43 AM
2008-06-12 08:19 AM
... And on Windows Vista!mate, I think you are entitled to get the medal for bravery...
2008-06-12 09:39 AM
jorgec wrote:Yes, answers from dedicated AC-users. But what I would have liked to see is answers/engagement from GS dedicated to their users. I find no dialog.
Patrick,
Jorgec,
Thank you for your answer,
.If a guest ask a question he'll get honest answers.
2008-06-12 01:06 PM
Chadwick wrote:How is Revit's performance on the larger projects? As bad as others claim?
Um, we do our projects entirely in Revit. 100%. Surgery centers, banks, office buildings, even a house!
Don't blame the software just because someone can fall back on ACAD. I know people who did this very thing in the last firm I worked in that used ArchiCAD. It has nothing do with the software and everything to do with the user. I've completed large projects in both. And on Windows Vista!
2008-06-12 01:59 PM
Thanks to you all guys.
Let tell you what we are doing after all.
The project itself is a Terminal building for a new international airport. so its about 130.000. m2.
The basic solution we adapted was, split the main plp file into 6 new plp files:
1. Interiors (walls, ceilings, furniture, storefronts, etc...)
2. Structure (for Concrete and steel structure coordination)
3. Envelope ( for the all the exterior walls, claddings, glazing work, Roof, etc..)
4. Services Coordination (HVAC, fire, electrical, wet services, security, baggage handling, coordination)
5. Procurement (for all the documentation regarding specs, quantities, etc...)
6. Site ( for the terrain, roads, and the general exterior works.)
Of course all the Layout books are in different files, with the drawings linked to the specific plp where the view was saved. (... we have just missing those old pmk files.... quick access to a view trough a stand alone file)
The plp can see the others plp information with the hotlink, and not everyone need to see the services or the site, so we basically linked the structure, interiors and envelope.
The graphical Standards have been coordinated manually almost every friday. Is not that difficult after all.
Everything is working good, but still id like to warn you about some thinks that doesn't work 100%:
1. Grid Lines:
Sometimes you have 6 or 7 grid lines on the sections, some times you don't have any.
BUT we have discovered that if you want to see grid lines on your section viewpoint, and the grid lines are not in your workspace or in a hotlink, you have to set the Status of the section to Auto rebuild, it doesn't matter if you rebuild it manually, it doesn't work. Only auto rebuild works... and is not 100 % sure.
2. Layout books:
Updating Views from different PLP files that are 60mb (+) size its tricky sometimes. for floor plans details and worksheets works almost at 90%, but for general sections, you can wait for 1 hour to rebuild it and maybe an hour or 1 day to get it into the layout book. It is still a problem. That's why i would like to use PMK files again. This gives you the chance of recovering old versions of the project even in 2D.
3. Xref Layers:
To be honest, working with so many consultants and contractors... coordinating structure services, details, etc... you can't always be sure that some one will forget to remove those layers..... Once those layers are in your plp you are lost. you can not erase them. Right now we can count around 450 Xref layers and 220 Project related layers. What a mess.
Just to finalise this, I love this software, even that Revit 2009 has a very nice Rendering engine, Even that Is not popular as Autocad. But we need more Reliability....
R E L I A B I L I T Y.....
2008-06-12 02:26 PM
Dwight wrote:Ooops a daisies. Of course 16GBMiki wrote:Perhaps you just need more ram.
Chadwick wrote:I blame the software for crashing, being slow etc. Like I mentioned at some level Revit become very unstable, and it is confirmed by Autodesk so there is nothing architect is doing wrong here. What is the size of your projects? How big is big for you? I'm talking about hospitals 600 000 sqft and 1.2 m. sqft. Do you use 64bit Vista? That was the solution for crashing in our case. Give it a 64 bit system and a lots of RAM. It did not solved a problem with being slow though.
2008-06-12 04:08 PM
2008-06-12 04:47 PM
2008-06-12 05:09 PM
