2005-10-26
05:43 PM
2023-05-23
03:33 PM
Rubia Torres
2005-10-26 06:25 PM
Alan wrote:Alan,
Hi Folks,
There are probably plenty of 'No' responses to the following, but anyway...
In AC9,is there a way to use the Roof Surfacer accessory on elements other than roofs?
or alternately,
Is there a Wall Accessory similar to Roof Surfacer for Walls?
I have seen Wall Surfacer for objectsonline, and have seen the CadImage Accesory Pack but neither seem to have the same geometry/functionality as the existing inbuilt Accessory...
Any guidance/info would be much appreciated...
Thanks
Alan
2005-10-26 06:46 PM
2005-10-26 11:24 PM
2005-10-27 01:12 AM
2005-10-27 03:32 AM
2005-10-27 04:22 AM
2005-10-27 10:51 AM
Peter wrote:Argh, sorry about that. All the time I was thinking of receding the window, which works fine for quick&dirties but requires additional objects if you need trim for close up views or sections. The additive approach to the ribs requires some cutting, but does make the trim less of a mess.
There is, however, a problem. I inserted a window into the wall and
the Operator mesh cut through it as well.
2005-10-27 11:30 AM
2005-10-31 05:40 AM
