Roof Eave
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-06-10
04:24 AM
‎2023-05-23
02:26 PM
Rubia Torres
Not to compare but Revit, as far as I know, does not generate this condition at corners.
Perhaps there is a way to clean it up by applying a fascia profile that trims the unwanted flange via material priority? I haven't tried that yet, still learning to work with profiles...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-10 05:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-10 02:27 PM
This happens sometimes and I'm never sure why. Same junction order, same material, same layer, reference lines meeting.
Whats happening to make them not want to join neatly??
thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-10 04:06 PM
But it looks as if you have something else cutting the bottom of the beams - maybe that is interfering with the connection?
Drag a copy of just the 2 beams away and then see if they trim.
If not select them in plan then FILE menu > External Content > Save selection as module.
Zip that .MOD file and attach it to the post here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-10 04:29 PM
Might help also.
Graphisoft Senior Product Manager
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-10 04:54 PM
Ive tried changing the junction order values for the beams in every combination possible including the beam underneath, but it has no effect.
What is even more strange is that there are 2 identical beams just next to these ones that trim correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-10 05:49 PM
But I realise may not be the best solution, because you'll be splitting the ridge beam at every intersection (and there seems quite a few).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-06-12 12:59 PM
