Roof Tool Geometry Method icon
Hi
Just changed to ArchiCAD14 and working on an older drawing for college.
Some how when I come to draw a roof and want to select the geometry method, the icons are not there.
I am sure there is an easy answer, but I have gone through all the toolbars when the roof tool is selected and it does not appear.
Any pointers would be most appreciated.
Cheers
7 Replies 7
David Maudlin
icebandit:
You should check your Work Environment. Either apply the Standard Profile 14, or if you want to modify the current profile, go to Work Environment > Tool Schemes > Info Box, select Roof Tool, then make sure that Geometry Method is visible and near the top of the list. It is also possible you need to scroll within the Info Box to get to the Geometry Methods.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Hi
Many Thanks for your time, I will try that out.
Cheers
Link
This is not the best place to post this issue. Working in ArchiCAD is better, but perhaps a moderator will move it.
Anyway, please upload a screenshot if you can.
Link.
Maybe you could reload the Standard Work Environment, see it that restores the icons in your Toolbar.
David Maudlin
Answered here:
David
This thread looks a little confusing. The reason is because I actually merged two topics but did not delete any of the answers in either.
Sorted, many thanks.
Haven't used it for ages, I was messing about in the tool box, but go far enough.
Cheers
