‎2014-11-10
10:36 PM
‎2024-05-16
01:33 PM
‎2014-11-10 10:48 PM
‎2014-11-10 11:01 PM
‎2014-11-11 01:15 AM
‎2014-11-11
03:31 AM
‎2024-05-16
01:34 PM
The problem is that the pivot point is on the bottom surface of the roof but the extent of the roof and the angle for the edge uses the top surface of the roof.
As Stuart mentioned if you want to leave the pivot line on the edge of the wall you need to work out the roof offset (overhang) that you will need.
You can measure the distance but it will not be perfectly accurate as you will be missing the decimal accuracy that you will only get if you draw a line and copy & paste it, then use that line as a reference to stretch the roof overhang as Stuart mentioned.
Image attached for clarity.
‎2014-11-11 03:37 AM
‎2014-11-11
03:38 AM
‎2024-05-16
01:35 PM
The finished product.
If you have a zero offset in your roof you will need to type any figure in so you can stretch the roof edge rather than the pivot line (i.e. you have to separate them to select the roof edge).
‎2014-11-11 06:52 PM
‎2014-11-11 07:53 PM
‎2014-11-12 01:56 AM
NCornia wrote:Thanks Nicholas,
Hello Gents,
I have taken note of this post and will put it to the attention of our product team.
Best regards,
