Roof angle
Blue
More a wish / feedback probably. Or have I missed this somewhere? Then please let me know.
I wish it was possible to have different angles on a pitched roof.
I find it way to much complicated to test out different roof angles.
Skjermbilde 2025-02-03 kl. 10.03.04.pngSkjermbilde 2025-02-03 kl. 10.02.56.png
14 REPLIES 14
Need to do more gables!
Thanks for all answers, I will study these options 🙂
Blue
Just a small following up for a different project. I tried the adding roof-ends from:
Miha Nahtigal
That is an easy task. Select a first roof and control+click on the edge of the second roof you want to merge. Than repeat the procedure for the second plane.
- On a multi-plane roof, but could not figure it out. I guess I would have to do the single-plan roof also in this case?
In that situation I would just set them all to Vertical, then select the end edges and open the pallette settings to change just that edge to Perpendicular.
Ling.
Custom edges..Ah, thanks ðŸ˜Œ Can not believe I have not disoverd that before.
