2025-02-03 10:23 AM
More a wish / feedback probably. Or have I missed this somewhere? Then please let me know.
I wish it was possible to have different angles on a pitched roof.
I find it way to much complicated to test out different roof angles.
2025-02-04 03:59 AM
Need to do more gables!
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2025-02-04 01:01 PM
Thanks for all answers, I will study these options 🙂
2025-02-24 10:16 AM
Just a small following up for a different project. I tried the adding roof-ends from:
That is an easy task. Select a first roof and control+click on the edge of the second roof you want to merge. Than repeat the procedure for the second plane.
- On a multi-plane roof, but could not figure it out. I guess I would have to do the single-plan roof also in this case?
2025-02-24 10:20 AM
In that situation I would just set them all to Vertical, then select the end edges and open the pallette settings to change just that edge to Perpendicular.
Ling.
2025-02-24 11:19 AM
Custom edges..Ah, thanks 😌 Can not believe I have not disoverd that before.
