Roof fill
jss
I use the old Archicad 20  - For some reason now any roof I make appears with a black and magenta colored checkerboard pattern in 3D. I cannot find where to change this.  Need help
JS
@jss wrote:
... it will not show standing seam on the color I use for the modeling
You need to add the image used for the standing seam into a loaded library.
4 REPLIES 4
DGSketcher
Legend
That checkerboard indicates that the previously applied surface e.g. Tile is missing. You need to change or check the building material and the associated surface finish you have assigned to the roof.
jss
That works, Thank you.......but it is limited - for example it will not show standing seam on the color I use for the modeling
But that is better than nothing. The modeling I so is simple not for rendering.
Thanks
jss
Thank you again
